MoTeC M150 Harness build for MKIV Toyota Supra
EFI Wiring Fundamentals
Hi All. I have started the Motorsport Wiring classes and need some professional assistance. I am in the beginning steps of a pretty large scale build for my 1994 Toyota Supra. I am seeking assistance regarding the wiring, connectors, wire ga (size) selection, circuit planning etc. I will link a spreadsheet that is pretty detailed so please reference that.
The basics of the build
MoTeC M150 with ProDrag Firmware
6 FIC 1050cc Injectors
6 FIC 1700cc Injectors
6 IGN-1A Haltech Ignition Coils
OEM Crank and Cam sensors
5 BAR MAP Sensor
IAT Sensor
Fuel Pressure Sensor
Transmission (T56 Dogbox) Input shaft speed sensor
Transmission Oil Temp Sensor
Diff Oil Temp Sensor
Turbo Speed Sensor
Exhaust Backpressure Sensor
Ambient Air Temp Sensor
Oil Pressure Sensor
Oil Temp Sensor
Coolant Temp Sensor
Coolant Pressure Sensor
Strain Gauge Shifter
VVTi Cylinder
Flex Fuel Sensor
Drive-By-Wire
MoTeC LTC Wideband
MoTeC 8 Button keypad
Where you see "Firewall Connector", I plan to have a bulkhead Autosport connector (Open to 1 or 2) mounted to OEM ECU wiring part of the firewall. I plan to build a secondary harness for the interior of the car to handle things like the strain gauge, fuel pump PWM, CAN-Bus items, etc.
I would like some assistance with making sure I have the correct design idea at the moment. For a majority of the harness, I have selectee 20 AWG M22759/16 Tefzel wire from YourSpec with laser marking on the wiring. From what I understand, I should isolate the 12 volt grounds so no sensor shares ground with either the ECU itself or the half bridge pins.
As far as the IGN-1A coils, I have read all kinds of conflicting information. I've read to feed all 6 coils with a single 10 AWG power wire. Then I have read that it's ideal to split them into pairs of 3 and feed 3 coils with a shared 20 AWG 12+ feed, then the other 3 with another shared 20 AWG circuit.
Now how about the fuel injectors. Is it best to feed each 6 injector set (12 injectors total) with a dedicated power and ground? If so, AWG size?
The M150 has 3 12 volt positive pins (B13, B19 & C26), for reference.
I will stop the explanation here to see if this post gains any traction.
Thanks!
