R32 SMJ pins
EFI Wiring Fundamentals
hey! does anyone know off the top of their heads where i can get pins or who and what model of pin is used in the R32/S13/S14/S15 SMJ body connectors? i find these connectors super useful when building new chassis harness for some of my cars. ive had no luck comparing pins but these are also 30 years old so im sure pins have changed a little! thanks for the help!
Wow, they do look like a handy connector!
The 6 larger pins look like standard 6.3mm tabs, the same sort you'd get with a relay connector.
Can you pe-pin one of the smaller pins and post up a photo? They look similar to an 070 or 040 multilock.
