Relays
EFI Wiring Fundamentals
I have normally closed and normally open devices that I want to activate at the same time . Am I correct in thinking I can connect the open to 87 and the closed to 87a on a 5 pin relay
yes that should work fine
Thanks Ross I appreciate the prompt response I have been trying to work this out for a while I found the answer in the wiring fundamentals course and just had to ask the right person the right question to confirm thanks again
