Rotary switch
EFI Wiring Fundamentals
Hi brains trust
would a 2 wire rotary switch for different tunes go go to pull up analog or digital on the ECU
Hello Brett it can be wired to a digital input wired to either depending on the ECU used, normally i would use a digital for only a two map selection
Regards Ross
Thanks Ross
it is a Emtron KV8
