Shielded cable
EFI Wiring Fundamentals
Hello HPA
Whats the best way to pass through shielded cable through a mil spec connector. Can you still do a service loop in side the heat shrink boot and not get signal problems.
I wouldn't be afraid of doing so, as any signal that would be picked up be drained to the ground.
The recommended way to do this would be to use a sealed solder splice and splice a 22/24 awg wire to the shielding on the cable itself. Then pin that wire into the connector. HPA has some good videos on YouTube demonstrating the best way to do this.
https://youtu.be/BOmo0Vy5DyE
Thanks Zack
