Solid state relay and DEP relay holder
EFI Wiring Fundamentals
I am looking for solid state relay and GEP solid state relay holder,
Could you please inform me from where I can order those parts?
G'day Antonis. Going to need a little more details here mate. There are lots of different types of solid state relays. Can you give some more info, pics of what you're after and I'll try and suggest a supplier.
Hi Zac,
First of all I would like to thank you for your fast response.
I have attached the diagramm of the power supply I want and also the solid state relay and relay-fuse holder.
If you beleive that for my project another relay or relay holder are better will be helpful.
G'day Antonis.
Your diagram looks good. What kind of shift light are you planning on running? It probably doesn't need a relay all to itself, as they don't typically draw a huge amount of current. You could power it from the ECU (Main) relay possibly, and use the ECU to provide a ground to turn it one when needed? Will all depend on the model.
The GEP relay holders are great, however I don't have any experience with the MicroPlex relays, so cant advise you there. I haven't found any solid state relays that fit the micro iso280 format unfortunately.
Thank you Zac.
I have attached photo from the shift light I use and also i would like your opinion about MSD solid state relay block photo has already attached.
I couldn't find the Microplex SSR18 1.135.300.00 anywhere.
Where did you bought yours?
I could not find also.
