Subaru MAF DIY Wiring
EFI Wiring Fundamentals
Hello,
looking to get some help on doing a DIY MAF wiring to a 2 wire TurboSmart IAT sensor. Previous owner already cut up the OEM MAF sensor and I just did an entire bottom end rebuild of the car(see details below). Already tried to conduct first start procedures multiple times and the car dies in 5 seconds.
COBB Accessport reads 0 volts for MAF, but the it reads the air intake temp fine. (See video)
I would assume that having no MAF volts is the issue why my engine isn’t starting. (Unrelated or not, I do have a small rear main seal leak, and my oil pressure gauge is faulty(AEM)).
anyone know of having 0 MAF volts would cause the engine to die?
10 STI Hatch Build
Ej257 OUFRONT Closed deck seasoned case halves with bore set at 99.75mm
STDX main Journal Bearings
JE 99.75 Pistons
Manley Turbo Tuff I beam rods STDX rod bearings
ARP ROD BOLTS stretch @ 1).061 @45ftlbs 2) .061 @50ftlbs 3).059 @45ftlbs 4).060 @50ftlbs
RCM 1.1mm Head gasket
ARP2000 Head studs set at 120ftlbs~
Ferrea 1520p/1514P STD racing valves
Super tech dual valve spring kit
GSC Stage 2 272 deg Cams
Valve lash set @ IN:.008 EX:.010
Asin timing kit w/water pump with RCM race thermostat and housing
RCM 11mm modified Oil pump(packed with Vaseline and locktight)
IAG turbo feed line kit
KilerB Competition Oil Pan w/Pick up
RCM Racing OIL BAFFLE
Cylinder 4 cooling mod
IAG AOS COMP V3
EGR Delete
-8AN fuel lines w/ radium FPR(w/ gauge)
FIC1450 Injectors
COBB Flex fuel sensor on Radium Adapter(iWire modified straight to the ECU)
Radium fuel filter 10 micro
Dual Walbaro 450 on Radium Fuel Hanger
OTL TGV Deletes
IAG fuel rails
Phenolic spacers
Perrin boost controlleR
Cobb 4BAR MAP sensor
MAF to IAT conversion kit
Grimspeed cold air intake
FRP Red 84mm Turbo w/ 84mm silicone intake
COBB FMIC w/ Perrin BOV(2015wrx)
AEM Oil pressure sensor(gauge faulty)
AEM AFR Gauge
IAG UEL Headers
CNT upipe
TurboSmart comp gate 40 external wastegate with 7psi spring
Invidia catless DP
Express single exit catback
EXEDY Twin disc clutch(rebuilt from triple disc)
Derek,
Without a mass airflow sensor signal, you'll need some manner of airflow calculation for the vehicle to run. Without seeing airflow, fuel requirement can't be determined properly, nor load, etc.
Determining airflow can be done with a speed density model if you're using tuning software/hardware that supports that i.e. COBB.
So I do get air flow and air temp signals, just no MAF volts.
Mass airflow is generated from a failsafe state based on throttle, RPM, manifold pressure when the MAF is unavailable, or if you are running a proper SD setup, then airflow is generated from the SD model.
