VAG Coil Terminals
EFI Wiring Fundamentals
I am having a difficult time finding the correct terminals for the VAG / Audi R8 coils using VW connector shell 1J0998724. Almost every site sells these with a 2.8 mm "junior timer" terminal that fits loosely but if you look at the terminals that VAG uses, the body is longer and closer to a Bosch BDK 2.8 or TE MCP 2.8 (but the spring retainers are further forward on these terminals vs. the VAG version)
Does anyone have a VAG part number for the correct terminals to use with this connector that you can share?
Screengrab is from this video: (4) VW and Audi Wire Terminal Removal DIY (How to) Including Replacing an Ignition Coil Connector - YouTube
Thanks in advance!
Edit: I believe the terminals are VAG 000979141E, I ordered a few to confirm.
Interested in this. This marks the 3rd variant of the VAG coil connector I know of, all with their own terminals. Both the ones I have fit the coils just fine.
