Wheel speed sensors
EFI Wiring Fundamentals
Hello everyone,
I was wondering if someone may be able to tell me what type of sensors the factory R32 GTR uses for the wheel speed/abs?
I'm trying to figure out if they will be compatable with my Link ecu, or if i need to change them to avoid issues between it and the factory abs ecu.
Thanks!
What specific Link ecu do you have and what are you wanting to do with individual wheel speeds? Obviously you will need to keep the factory sensors if you want to keep factory ABS. Typically the ECU just gets speed from the gearbox sensor or a conditioned signal from speedo if it is cable speedo.
