Wire size when daisy chain for sensors
EFI Wiring Fundamentals
I'm adding a fuel pressure and oil pressure sensor onto an AEM Infinity system. Was planning on using 22g wiring. Any reason to step the wiring size up if I am daisy chaining the 5v and sensor ground wires for them?
A single 22 ga feed could probably handle 10 sensors.
How long will the loom be? As long as you do not have a voltage drop over the wire run then the 22g should be ok.
Thank you both. It wont be very long at all. Maybe 4 feet long.
