Wire sizing question(s)
EFI Wiring Fundamentals
Hey Folks,
First of all -> Happy New Year :D
I have 2 questions about the right wire sizing.
1. I have an GM LS3 and the starter solenoid wire is 14 AWG. My automatic transmission shifter hast an included neutral safety switch and the integrated wires are 20 AWG. I also have a ARC switch panel with fuses and relays, so my start button has already a relay.
Q: Should I cut the 20 AWG as short as possible and use 14 AWG for the rest? Or should I use a 2nd relay?
2. I have a transbrake button on my steering wheel, the wire of the curly cord will be 20 AWG (most common in the market is 23 AWG!!!). With this button I power the transbrake solenoid, the launch control and the backup light. Usually I would run a 16 AWG wire from the button and spile it into 3 18 AWG wires.
Q: Anyone with an advice, recommendation and explenation?
Thank you in advance and best regards
Bjoern
