wiring a distributor
EFI Wiring Fundamentals
hi, i just got done watching the ignition configuration and testing. and as you stated i wont be able to test a distributor type engine unless its working. so my question would be, on a standalone ecu how would i wire the ignition outputs to a distributor, or would i not be needing to use it?
Hi Darian,
It will depend on if your distributor has a ignition driver or not. If it does then you will need to use an ignition output from the ecu to this driver.
So therefore if it does have an ignition driver I would only need to use one ignition output from the ecu to the driver
