Block preparation deburing examples
Engine Building Fundamentals
Can you include before and after picture examples of the describe areas that we might want to debur?
I'll see if we can do this on our next worked example as it's a little tricky now to go back and do this with the completed worked examples. I feel there's sufficient detail in the body of the course discussing what you should be looking for though.
Looking at my block I found a flashing candidate that I should remove. It is close to the lifter bore, but I think I can get to it and clean it up. I really don't like the crack, but I think it is just flashing.
Hi Charles, yes that's a perfect candidate for a little attention with your die grinder!
Thanks, I'm really glad I paid attention to this. I touched the hole with the grinder and a 1/4" chunk fell off. Looks better now.
Perfect!
