Fa20 Engine Performance Bulid for forced induction
Engine Building Fundamentals
Setting Ring Gaps
Clearance For camshaft and springs what is the correct gap.
What does the Factory Workshop manual suggest? Any further recommendations from the ring or piston manufacturer (if not using OEM parts)?
What is your target compression ratio? What is the maximum boost?
What is the intended use -- 1/4 mile? Road Racing? Bonneville? Street cruiser?
