Issues with new Engine Building Fundamentals course
In addition to the wrong video for Using a Bore Gauge, I noted two other issues:
- There is an echo in the audio @1:56 -2:04 in the Installing Pistons On Conrods video within Engine Longblock Assembly
- The Request Certificate is missing the Certificate Request Form. BTW - I don't think I have ever received a certificate and I believe I have requested them.
Other than that -- well done! I think you should use more talking over pictures showing what you are talking about. For example, you talk about the necessary tool to measure the weight of big and small end of the conrod, and that tool is on the bench right behind you. A video showing that with the big end on the scale and then small end while you are talking about that may be more effective.
Thanks David.
We have updated the Installing Pistons on Conrods Video. Thanks for pointing that out.
The Request Certificate page is back up :)
Totally understand your point. We have released a Practical Engine Building course which contains more hands on practical lessons. We will be using some of the b-roll from this course in the Fundamentals course.
Thanks for your feedback. I'm also on the hunt for testimonials to use on the course page, if you are interested fire me an email ben@hpacademy.com
Cheers
