Ring Gap grinding tool
Engine Building Fundamentals
Hi
Do you have any recommendation for a ring gapping tool?
We do 1-2 engines per month. Would you invest into an electric ring gapping tool or do does a hand tool the job?
Hello i personally use a hand ring grinder from summit in usa. if using a electric one it is easy to over grind so i recommend practice on some old rings first
Regards Ross
