Static balance
Engine Building Fundamentals
I would like to know what are the advantages of the static balance of the components of a 4 cylinder engine (pistons and connecting rods) to give customers an idea of ​​what it should be done and if it affects the engine horsepower at the end of the assembly and tuning
Balancing an engine's components reduces vibration and harmonics that occur during engine operation. You'll typically notice a balanced engine is smoother in operation, revs more smoothly, and can produce a small increase in power. It may also offer improved service life too.
thank you very much for your reply
