Cooling properties of E40
Ethanol & Flex Fuel Tuning
Hallo,
It was said in the course that an ethanol blend of 40 percent has a high knock resistance already and the gain above will be not that much.
How about the cooling properties of E40? Can I expect a clear improvement compared to pump gas?
Thank you
hello yes you will see an improvement in cooling the amount will depend fully on the engine and current cooling system
Thank you. Really excited to the result.
