R32 GTR Prep for Haltech PnP install
General Car Setup Discussion
I'd rather look silly but be sure rather then assume. As the title says, making a post in regards to running the Haltech PnP for the skyline to replace the OEM ecu for engine management.
From what I've been able to gather via resources, it seems that aside from a WB O2 (for more extensive tuning) is required for full proper operation. This is also taking into account replacing the intake temp sensor and switching over the OEM boost solenoid to a 3 port mac valve.
I just want to make sure if this is all that really is required or are there other items that are needed. My goal is to have everything sorted so by the time I take it to a tuner (or manage it myself, but much rather the former) everything that is needed to have things run smoothly are in place.
TLDR, what's needed to really make this a "Plug in, off we go" affair.
Thank you for your time.
