Advice on turbo for an 1uz
Hi looking for an turbo charger for an 1uz not an high revving build as it going to be build for off road bakkie max rpm will be 4000rpm and will spend most of it driving at 1500 to 2000rpm but need power to pull from there if needed
the garret 3582r with a small exhaust housing is what i have used but my redline was 6000 in a off road truck so im picking you would something like the 3082r to suit your response needs
Regards ross
