Compression tests
Does it affect the results when doing a compression test on an engine without a gearbox mounted on to it for example a junkyard engine or trying to buy a used engine from a shop.
No, the gearbox doesn't affect the compression, you just need to make sure you can get it cranking at 200 RPM or higher
