Cylinder head compression
https://youtube.com/shorts/RrapYdFTiOc?feature=share
Hi Everyone
Could you tell me if this video through link attached
is the correct way to check compression ratios?
Thank you
Gerrit
No, that is a a joke. The only thing true is at the end where he says "this motor is basically shot". True that.
Dear David
I appreciate your input.
Kindly appreciated.
Gerrit
