Do i need the little end top oiling hole if the rod is rifle drilled
Do i need the little end top oiling hole if the rod is rifle drilled?
No, the drilling should be way more than required, just remember to make a corresponding hole in the rod' shell to feed the drilling.
lucky that the bearing already has a hole for the old squirter in the old rods
