honda s2000 engine f20c piston and cylinder clearence
Hi everyone, I wanted to know if anyone knew anything about the piston and cylinder clearence of a Honda S2000 F20C engine because it seems a little tight to me. I'm waiting for news
thanks
That is what I'd expect for a factory cast piston. they don't expand as much as a forged piston due to the higher silicon content. If you're using factory parts then there's usually no reason to stray from Honda's specs.
