Oil filter relocation Pros and Cons
Hi there,
I would know your point about to move the filter from under the block to the back of the RH headlight on my Impreza GC8.
I like to do this for keep the filter cool (far from headers) and the possibility to use a bigger oil filter plus oil cooler... I'm trying to understand: could I have any problems about the oil pressure?
Hello
I don't see any issue with doing this as long as you use the appropriate size and type of hose. there is no cons
Hi Ross,
thanks for reply. I would use -12 hose size for relocation and radiator...is too big?
Going to depend on your specific exhaust, but I'd just use a heat wrap on the exhaust. However, with well sized hoses and fittings (NOTE! Some fittings have a restrictive bore, but there are special fittings available with enlarged bores for performance applications), the pressure drop shouldn't be a significant problem - but use an oil pressure guage to monitor it!
The PRV should have enough headroom to accommodate a cooler but to be on the safe side I’d install a pressure gauge before, if the value is less post remote install I’d look at increasing pressure by shimming the PRV spring or replacing it with a stiffer unit.
