S2000 sheepyinc manifold
Hey could someone please explain why there is so much flow directed towards the wastegate What benifits does this have
Very accurate and precise boost control. It's a good design feature that won't overboost.
Exhaust gas is lazy and if the wastegate comes off the manifold at a horrible angle you'll likely see boost creep at high rpm. Sheepy's manifold is a case study in proper WG integration. A++
