Some questions about HPA SR20 VE build
Hey Guys,
I’m building SR VE build and I know you have lots of experience with this!
I have a P11 head and looking to make as much torque (low down power) as possible.
From your experience, am I better to order standard P12 Cams? What timing (how much advance) are you running? I’m looking at using E60.
Also have you had a look at the E&H Motors mod for this head that looks to at VCT to a VE head? It seems to increase mid range power dramatically. Is it worth looking at?
https://ehmotors.co.nz/product/sr20ve-vct-conversion-front-cover/
I know your VE head is CNC ported, but to get the best torque, am I better to go with std size valves or do you think I will see benefit in oversize?
interested in your thoughts on this. Looking to make around 600hp so nothing too crazy.
