Windage tray for 410w.
I'm building a turbo 410w. I plan on using a windage tray. There are basically 2 styles, louvered or screen. Is one better than the other? Thanks
I haven't built a windage tray but the ones that I've seen or used have all been a pressed steel design with what you could refer to as louvers designed to come very close to the crank/rods during operation. I can't comment on using a screen as I haven't used this style myself.
