1JZ-GTE EMU Black ECU
Hi, I have a 1JZ swapped SC300 running EMU black PNP harness. I loaded up basemap, car cranks but no start. The car has spark and fuel pressure. Attached tune and datalog of cranking. Thanks in advance!
Sorry Henry at this stage we've had no hands-on experience with the ECU Master products so it's hard to offer specific guidance. As simple first checks I'd suggest confirming the injectors are operating during cranking (use a LED test light) and if that's the case I'd check your base timing - It's also possible that the timing may be 360 degrees out (firing on the exhaust stroke). Beyond this I'd suggest you make contact with ECU Master for specific help.
