1jz vvti map needed
anyone has a ready map for 1jz vvti 1000cc id injectors with hx35 turbo or similar?
thanks in advance :)
First up it would probably be helpful if you let us know what ECU you're running for this 1JZ. Regardless of the ECU though, if you follow the 10 step process presented in our Practical Standalone Tuning course, along with watching the various webinars regarding VVTi tuning you will be quite capable of creating a map from scratch. This also means you're going to avoid any potential issues that may get baked in to a base map that you're provided.
Link ecu, just needed to start the car up :)
