4AGZE CAS to MAXXECU RACE
Hi team,
Im doing my research and documenting my wiring build before i begin making it.
one thing im stuck on is wiring the 4agze cas unit to my Maxxecu Race.
i have 4 wires from my cas unit and this is what i believe to be the way to wire it but not 100% sure and want it confirmed please.
i dont know where to connect the red wire from my cas unit?? Ive attached a copy of the pin out for the ecu for reference.
Any help greatly appreciated. Thanks
I'm not familiar with that ECU, but they list a crank trigger input in the wiring pdf you linked, so that's where I would expect the 24x signal to go.
Thank you.
With the multiple searches I did online I was getting told Hall effect and VR type so was getting a little confused as to if it needed a power supply but have just now figured it runs. VR sensors and that yes the red wire should be crank signal.
thank you
