Ends in 5 hours, 59 mins and 59 secs
I've fitted a fuel pressure sensor and have noticed that the fuel pressure fluctuates over time slightly. Is there a formula that I can use so if say the fuel pressure reduces by 1psi I should add X% if fuel?
I expect there may be an option with some ECUs - for those with the knowledge, exactly what make and model are you using?
I've got a Link G4X plug and play
Text
