5efe ignition characterization
hi all,
i am working on a customers car. Motor is basically a 97 tercel 5efe, Pistons, rods, custom cams, turbo and aem infinity. I would just like to double check the trigger info 36-2+1. If anyone can confirm that would be much appreciated
That is a 36-2 trigger wheel. I'm not familiar with that engine so it just depends what the sync trigger input is. A scope will confirm this for you 100% if you can't physically view the trigger.
