Advanced fuction , link ecu tutorial , RPM limiter
hi andre , how are you ,
i have a question , in some drift competitions , and auto cross competitions , the judges give additional points for the car sound , banging sound ,
can you make a webinar , On the advances functions for the limiter options and how can we make a banging sound on the rev limit ? for the ( LINK , MOTEC , Haltec , and AEM ) , for the forced induction engines , and the natural aspirated engines ?
thank you and best regards .
Most aggressive limiters with large bangs are when using an ignition cut as apposed to a fuel cut. However be careful when using and ignition cut on certain motors (likes sr20) as you will throw rockers off.
"However be careful when using and ignition cut on certain motors (likes sr20) as you will throw rockers off."
.... and possibly drop a valve, and ruin your engine ;)
Thank you chris , as usual you are always supportive , and thank you kg performance , thank you for replying .
The problem is most of them are asking for the banging saound , i dont usually do it . On link it is as shown in the attachment . And if you have any advice , plz tell , and i also wana know how i can operate this cut and banging sound on the haltech and aem and motec , if you have any info , i appriciate your help .
