AEM EMS-4 Alpha-n?
Hi guys...
A friend of mine asked me to tune his car a few months ago, At that time he was using a single TB with the stock inlet manifold so i tuned with speed density.
Now he changed all that and he's running itb's with no map and he wants me to tune the car again but this time using the TPS as load. The problem is that i can't seem to find that option in the AEMTuner software.
I was reading the ecu specs and i don't see anything related to alpha-n or tps tuning. It would be possible that the ecu is old and does not support tps tuning?
Thanks in advance.
Hi yes you can
Go to tabs > Hidden tabs and select TPS fuel it will open adv fuel window
Got it, thanks a lot!
