AEM V2 and Maxxecu for 2jz
Hi there,
i got problem with harness it need to be changed my tuner suggested replacing my ECU from AEM V2 to Maxxecu.
the car is fully built with GTX47 GEN2 and i would like to make the car as daily use as possible AC installed and looking for factory like drivability.
as far as i know the Maxxecu only reads 3bar. i need to professional suggestion.
hello, the maxxecu can also be fitted with any map sensor size. the best thing you can do is use a ECU your tuner is most comfortable with this will save you time and money if he is good with them
Regards Ross
