B16b
Hi guys just fitted a storm x to a ek9 still stock engine dnt work on these at all does anyone know if they are knock limited as a n/a
Hi Dan
what do you mean in your question ?
are you asking if the engine is knock limited ?
knock control is set up in the ecu by the tuner
can you maybe explain more what you want to know
Regards Ross
im I likely to induce knock as a n/a on 98octane fuel or am I going to need my det cans on
i would be using knock detection for sure
