Bosch 0261231006 doughnut Knock sensor into AEM series 1 EMS
Hi guys,
I have decided to go with an integrated knock sensor into my current setup which is a (as soon as i integrate the knock detection) high boost Honda LS-Vtec running AEM EMS series 1. The setup I am aiming for is a fast spooling high horsepower car for road racing. The car is tuned by me (thanks to HPA :) ) Anyways I have integrated boost per gear, however, I want knock detection using the Bosch doughnut knock sensor. I'm not worried about calibration, just unsure of the installation from the sensor to the ecu. I am including info for referance to help. Any help would be awesome. What I've gathered from my research; 1 wire to the knock sensor pin at PIN# D6, then the other wire goes to a 0V pin. my question is which pin would you guys recommend the 0V wire go to?
Connect the other pin on the knock sensor to one of the pins labeled 'Sensor Ground' or 'Analog Ground'. Pins B14, B22, D11 or D12 should work.
