Crank trigger wheel with motec M1
On my Evo im currently running stock trigger wheel as you know its not ideal.
I have an 18-1 trigger wheel im wanting to fit (widely used in the syvecs world)
has anyone fit such a trigger plate on an evo or any other make have you encountered any problems.
Any advice would be great cheers
I've only used either the stock trigger system or a 12 tooth crank trigger with a single cam sync. That being said there's no reason why an 18-1 crank trigger isn't going to work for you. The missing tooth trigger system is much less sensitive to the alignment of the cam sync too.
