Hi guys, anyone knows who makes chopper wheels for the Cam sensor housings, I can find aftermarket relocation housings, but I need as well the chopper wheel (4 tooth) and the slotted conectór that attach to the groves in the camshaft.
I missed the opportunity of buying a CAS sensor now I can't find one, but aftermarket housings are available but I guess without internals.
Or if you know that the one from another engine will fit or can be adapted easily, that will help as well.
Anyone does road race with your Evo, will the two coil waste spark system work with sustained high RPM's?
Is that what you are looking for?
https://longboostperformance.com/products/evo-4g63-cam-sensor-relocation-kit
Hello George, no that is available by different manufacturers, that is no problem to find, what I'm looking for is the internal trigger wheel, called chopper wheel as well, 3 image in the link.
Unless thes aftermarket relocation housings come with the trigger wheel, but I don't know.
or if someone has the OEM part number from mitsubishi, maybe I can see if I can order these from the dealer.
https://support.haltech.com/portal/en/kb/articles/4g63-trigger
I believe you are looking for
MD 184529. I've seen it on ebay....
Thanks George, as soon as I get my paycheck I get it if no one get it first.
Text
