DBW conversion, what cable to wire the sensors with?
I have an S15 with a 2JZ conversion, ive installed a Bosch 82mm DBW and 350z accelerator pedal with sensor.
Ive bought the plugs and pins for both sensor and wanting to know what cable to purchase, if I need to use SHEILDED or TWISTED pairs etc?
I just don't want any issues with noise etc
6 cores are needed per sensor
Thanks guys
shielded wiring is not needed at all but if the wiring happens to go close to the ignition coils or alternator ( within 100mm) then should the sensor wires, the positive and negative wires do not need shielding at all and twisting is also not needed.
Only 20 AWG TXL wire is enough
