DOUBT ABOUT ORDER OF COURSES
HELLO, I HAVE A QUESTION ABOUT THE ORDER OF THE COURSES, I IMAGINE THAT IT IS BETTER FOR EACH ONE TO START WITH A DIFFERENT ONE. IN MY CASE I AM DEDICATED TO MODIFYING CARS, MAKING THEM FOR CIRCUIT AND DOING REPROGRAMMING FACTORY CARS, BUT I WANT TO LEARN HOW TO MODIFY PROGRAMMABLE CONTROL UNIT AND KNOW HOW TO ADJUST THEM PERFECTLY FOR ANY CIRCUIT SITUATION, BUT I WANT TO KNOW IN WHAT ORDER WOULD BE BEST FOR ME SEE THE COURSES TO BE ABLE TO ADVANCE BETTER IN MY PROJECTS, THANK YOU.
did you check the courses for the EFI tuning? There you can find courses marked from Step 1 to Step 5, or buy the Tuning "how to" starter package.
Hey there Francisco,
This might be easier to discuss with you via email - support@hpacademy.com
I won't leave you empty handed here though.
There is no set order for topics as such, as what you should start with depends a bit on what you want to do first, and what you want to do first probably relates to what project/s you have access to or are planning to undertake soon.
I will give you an example. You say you want to modify cars for circuit racing. Are you already racing? Have you done some basics around alignments and driver training? If not, that is some low hanging fruit that I strongly recommend you dive into as both only mainly cost you time (comparatively to modifications etc).
If you wanted to tune your factory ECU first instead, you should begin with the EFI Tuning Fundamentals course, then Understanding AFR followed by the Practical Reflash Tuning course.
The software and hardware you need to tune a car varies from car to car, and some have more options than others. I would start looking into that after the EFI Tuning Fundamentals course as there is some content in there that helps you further understand that point, as does this webinar.
I have attached a quick 'course map' PDF with the bulk of the current courses so you can see how the content is laid out in general.
Hope that helps.
thank you very much for your answers! contact you by email to explain my case and my projects well so that you can guide me in the best order in which I can do the courses, thank you.
No worries at all, we'll keep an eye out 😎
