Drive by cable calibration on vipec
Hello my lovely friends I have a jetski yamaha fzr supercharged with vipec ecu my drive by wire was destroyed so I decided to change it to drive by cable but I don't how to calibrate it in my g4link software
hello the calibration section is up in the ecu controls tab at the top of the page this will bring up a drop-down scroll to the bottom of this and you will find tps set up
follow the icons from there
Regards Ross
You will also need to go to the E-throttle menu, set E-throttle mode to OFF. Go to analog input menu, turn off APS sub, APS main, TPS sub.
Then do your manual TP calibration.
Thanks guys I appreciate it so much very lucky to be here
