Duel Fuel Injector Housing TGVs
Didn't know if this needed to be posted on here or the engine forum discussion.
I have a Radium Duel Fuel Injector housing. They are basically TGVs with an extra 45 Degree port honed in the side for the extra injector
My question:
"Which is the most effective aftermarket stand-alone ECU to take advantage of this dual port injector function?
OR...is it possible to adjust the OEM ECU to repurpose say the TGV connector to run a dual injector port, maybe?
I was thinking either a Haltek Elite, Link ECU, or AEM Infinity but I'm secretly hoping that I can do this just through ROM Raider and ECU Flash, lol!
Are you wanting to run two different fuels, or use staged injection?
I'm sure you could just run two injectors in parallel (and change the appropriate injector scaling info in ROM Raider if you wished. But usually it's easier to just get larger injectors.
J,
The stock ECU won't do this.
Out of the 3 standalones you mentioned, I'd use Link, but technically they can all control 2 sets of staged injectors.
