ECU Tuning Equipment
I'm new into the tuning world and wondering what cable I should be using for the connection between my ECU to my laptop. I've heard that OBD2 to USB isn't a good way to go? Just wondering if there are any brands or connection types that I should be using to hook up to my car :)
Many thanks to all in advance!!!!
It depends on the ECU, most Standalone ECU will use either Ethernet, USB or even RS232 Serial in some older ones. OEM ECU that can be re-flashed generally use USB-OBD2 adapters such as HP Tuners, EFI Live, etc.
