ECUMaster EMU - Trouble setting trigger on VW 1.8T 20V Engine
Hello, I am in a bit of a conflict about which trigger setup is right.
Current setup I will attach picture and check. I am mostly unsure about the secondary trigger,
Trigger type: VW 1.8T - The synchronisation (cam sync) occurs in the case the time between 2 previous teeth (prevDT) is less that the time between previous and current tooth (DT) multiplied by 0,66.
prevDT < DT * 0,6
N+1 60% - The synchronisation (cam sync) occurs in the case the time between 2 previous teeth (prevDT) is greater that the time between previous and current tooth (DT) multiplied by 1,6.
prevDT > DT * 1,66
I am running second option currently, and had no problems, but why is the 1.8T 20v one different? Can you post your 1.8T trigger setup?
