EFI Tuning by Gear
Does the VE table change based on the gear you are in?
No.
But, it acsesses different load cells.
if your seeing different afr under full load at the same rpm points in different gears - thats fairly "normal" from what i've seen on different cars and ecu's
if your ecu lets you, you could run a gear correction map per gear for fueling if you want to get things more accurate in all gears - or turn on wbo2 correction for the whole fuel map and leave that running all the time maybe.
