emu black sensor setup
just wondering if anyone can tell me on the emu black if theres a way to add and configure custom inputs from extra sensors from a can switch board.
i have an emu black and want to add a can switch board with pre intercooler pressure and tempreture. pre turbo pressure and temp aswell as my water to air intercooler water pressure and temp before and after intercooler. i cant seem to find anywhere to add and define extra sensors and wonder if its even possible or is it limited to the predefined input sensor selection already in the emu black
thanks in advance
You can use either ADU dash or can switch board.
Switch board gives You 8 digital and 8 Analog inputs. Then You can send it via CAN BUS to EMU. Then use this data as needed.
