EMUBLACK Overrun fuel cut
Hi all,
I have EMUBLACK on 1JZ-GTE with single turbo conversion. I cannot get overrrun fuel cut to disable, even after setting the fuel cut rate to less than 100% and setting the ignition disable on overrun events, still will not keep the injectors cycling during overrun.
Wanting to keep the injectors firing for a few revolutions after closed throttle and have fuel dump into the cylinders for cylinder cooling after throttle lift off.
Is there a setting I am missing in the fuel cut parameters?
Thanks,
Craig
Just to be sure, you are logging the injectors pulsewidth in order to verify if it's still injecting fuel? If you are only relying on a wideband and you disable ignition on overrun events, you won't have combustion and the wideband will read full lean.
