FRS/BRZ ID 1050X Injector Scaling
Does anyone have a good injector scaling and setting for Injector Dynamics 1050X on FRS, BRZ or Toyota 86 on stock ecu?
Sorry I've only run the ID1050X on our 86 with the MoTeC M150 ECU. If you follow the injector scaling module in the Practical Reflash Tuning course though you should be able to get the scaling dialled in pretty easily.
